Hello, is possible to share CAD model in step?
JaneYu 2021-06-28 15:35:37 9 Views4 Replies Hello, is possible to share CAD model in step?
here are the results of some tests:
voltage 12V
current 0.28A
No load (no torque involved)
T° after 4 minutes : 85°C
T° has been recorded with a K probe thermocouple on the insulating .
after reaching more than 80°C, the motor begins to turn non continuously (eratic turns)
So if the motor is powered at its nominal value, it will rise its T° until working eratically.
May you please conducts your own tests and tell if it's a standard behavior or a malfunction ?
Thanks in advance.
Cedric Bourgoin
JaneYu hi, considering that there are magnets inside the motor, I don't think they will support the 100°C Temperature for long before being damaged :)
I will proceed to measurment at mid april and comiong back with better informations.
Thanks for the reply .
JaneYu
