How to check the OBLOQ is working properly? I connected with Microbit and always got the red light on it. I also hold the reset button for a while.
userHead JaneYu 2019-05-03 07:47:49 10 Views4 Replies
2019-10-03 16:38:20
How can I upgrade the firmware? It says it's 1.0, but there's 3.0 available on firmware page.
2019-08-26 09:40:55
How would I connect this to I/O Expansion Shield?
Hey Quang,
The simplest solution would be to use a full digital row on the board (so power, ground, and one analog port) and then plug the second digital pin into the adjacent digital pin only. For example, you could have power , gnd, and RX be on the digital pin 7 row (using the red, black, and green pins) and then just have the TX pin be on the 6th row digital pin (green color pin only). If you need further assistance, please let us know!
2019-08-26 10:08:50
2019-05-06 11:11:53
Red light means the wifi is not connected. Please check if you got the wifi id and password right. Instructions of using obloq could be found here: https://wiki.dfrobot.com/Gr...
