Hi - Can you use TFMini with Arduino Feather BLE 32u4? Thanks
JaneYu 2019-09-27 06:39:50 10 Views4 Replies Hi - Can you use TFMini with Arduino Feather BLE 32u4? Thanks
Hi guys. The minimum resolution I get is 10mm. The specs on this page say is has a resolution of 1mm. https://www.dfrobot.com/pro...
The specs on this page say is has a resolution of 5mm. https://wiki.dfrobot.com/TF...
I need it to have a min resolution of 5mm as advertised when i purchased. Is there a way to have the device produce readings in 5mm steps rather then the 10mm that it is giving me now?
JaneYu If water or glass is ignored, do you mean that it measures the distance of the measured object correctly? Or do you mean that it cannot measure if glass or water gets in the way? Sorry for my english level
JaneYu Hi, there will be some effect that the glass and water change the detecting light of the sensor.
has anyone used this with a SBC like a Raspberry Pi? I would be willing to serve as a developer/tester to create the software etc. to make it work if no one has done this already
JaneYu
