Nice case, but a push button for activating shutdown is missing to make this case complete. I wonder why case manufactures do not add a pushbuton or two.
JaneYu 2020-06-11 17:11:03 31 Views6 Replies Nice case, but a push button for activating shutdown is missing to make this case complete.
Its bc software is also needed to trigger shutdown. Pi is meant to be a cheap diy educational comp, and a lack of on/off switch is one of many sacrifices they made.
JaneYu No, I am asking whether this case will block the wifi signal from the RPi. Similar to how a faraday cage blocks EMR waves (or how your phone stops working in a metal lift).
JaneYu Hi, this one is for raspberry pi to dissipate heat without blocking wifi signals.
c'mon guys, has anyone tested this to work with wifi?
JaneYu 1 week bump... seriously. Could I get an answer, waiting to order but need Wifi reception.
There's no push button on the Pi either. What pins need to connected to initiate shutdown? I only know of hitting shutdown on a display.
JaneYu
