compatible with romeo ble v1? does data from the 9axis Sensor go to Serial Print, and then could you write code using the sensor data output to maintain a certain orientation of th...
JaneYu 2021-01-17 12:58:20 26 Views2 Replies compatible with romeo ble v1? does data from the 9axis Sensor go to Serial Print, and then could you write code using the sensor data output to maintain a certain orientation of the sensor using motors from the romeo ble?
