How to switch the address on the chip from default?
JaneYu 2021-03-28 11:08:56 60 Views2 Replies How to switch the address on the chip from default?
2022-11-22 13:19:48
JaneYu
This is from the datasheet:
Pin: 9Name: ADDR_SELDescription: Select IIC address: 0x45 in low(in default) / 0x5B in high
So it seems like you would use pin 9 to swap between 0x45 and 0x5B. Good luck!
JaneYu JaneYu
wrote:
2022-11-22 13:42:47 1 Replies
Hi! IIC address default 0x5A, the address becomes 0x5B if the ADDR_SEL is soldered.
