could you use this shield with the DFRduino Mega1280
userHead JaneYu 2022-05-24 05:45:00 112 Views3 Replies
2024-06-05 01:58:26
im trying to run this program but my sim7000A never turn on and keep saying failed to set baud rate
If your serial monitor freezes at the Set Baud Rate step, it may be due to insufficient power supply (this product requires 7~12V for the Arduino) or the on-board jumper caps are not connected correctly (TX-D8, RX-D7)
2024-06-05 10:08:08
2021-04-09 02:14:59
What are the power supply requirements . . . other boards with this chip require external power in addition to voltage supplied from the Arduino.
