Can I use it for wrist based appliacations? In the MAX30102 datasheet it is stated as a finger-based only.
userHead JaneYu 2021-05-06 19:30:24 92 Views2 Replies
2023-11-02 15:20:10
You can use this sensor on your wrist, but it may be possible to change the sensor to not perform very well on your wrist. We recommend using the sensor on your fingertip.
2021-12-21 03:23:44
When will this item be back in stock
