How can you change the id of “BT5.0-Audio” to something else when you have multiple devices in the same area?
JaneYu 2021-05-22 02:28:28 98 Views4 Replies How can you change the id of “BT5.0-Audio” to something else when you have multiple devices in the same area?
Hi, Please send your connection code and related video to our technical support email [email protected]
JaneYu Thanks for the reply. not sure what a connection code is and what video should I send ,
My question was do the current models only beep when turning on and connecting? The one I have has a foreign voice saying "blue tooth on" and then "bluetooth connecting" . If the current ones only beep then I will upgrade as I really like the module other than the voice. Thanks again William
Does this board automatically reconnect or must you manually reconnect Bluetooth every time you power up? If it reconnects automatically, how do you tell it to connect to a different Bluetooth device?
JaneYu
