what's the status of the Mac support?
userHead JaneYu 2021-11-30 16:25:34 83 Views8 Replies
2023-12-18 21:30:43
Well it still does not work on mine.
Make this boards useless.
Tracking progress
https://github.com/jwilleke...
2023-06-29 18:53:36
If I would like to use such module for mass production - is it certified for Europe and available in bigger amounts? Is there anything else I need to care about?
2023-06-19 20:07:35
Greetings, installed Arduino 2.1.0, When installing the firebeetle URL for board manager get following error.
Some indexes could not be updated. Get "https://download.dfrobot.to...": tls: failed to verify certificate: x509: certificate has expired or is not yet valid: : https://download.dfrobot.to....
Do you have an updated package or solution to error?
2023-01-18 17:08:45
Sorry sir, you could refer to our PIN map in the wiki page, and the GPIO 0 is D5.
Thanks. Also the PlatformIO file for the firebeetle 2 does not work properly for me on Windows or Linux. There seems to be some issues with it. I have instead been using the Firebeetle 1 file and modifying some bits to make it work.
2023-01-18 18:20:08
2022-02-11 13:58:07
Hi, ESP32-E supports Mac, you can find Mac driver in FAQ section of Wiki.
2021-09-18 18:11:46
I have done that with mine and it worked fine. I used this ESP-IDF firmware esp32-20210902-v1.17.bin. The issue with mine was with the USB. I could only flash it from a Linux box. For some reason my mac doesn't recognize the usb. I have tons of esp32 and this is the first time it happens .
