Hi what audio amplifier chip is in use on the MangoPi-R3c? The marking on the chip does not match anything I can find online.According tohttps://mangopi.cc/Tiny200it's a PAM8403, b...
userHead JaneYu 2022-03-05 03:59:10 26 Views7 Replies
According to
it's a PAM8403, but this is just silly as that's a 6 Watt Stereo chip.
According to the schematic, it's a PAM8301, but first that part is discontinued, and also the PAM8301 should have a chip marking of FPXYW, which does not match the chip on the MangoPi-R3c board.
What make and model audio amplifier chip is it? I need to match a suitable speaker
Peter
2022-10-24 19:41:27
Where I can find more information about working with GPIO from Python?
2022-09-10 02:46:55
The camera firmware does not work with the MangoPi - see my forum post here
https://www.dfrobot.com/for...
It just displays a green square image. What is the solution for this ?
2022-04-02 21:47:43
Hi how do you enable USB OTG in your firmware?
2022-02-18 13:43:58
We are very sorry.
Our engineers have updated the software tool and you can retest it.
I got mine working now - using windows - dont bother using Zadig 2.5 - just run the tool - hold the boot button, and press reset and let go of reset (so it boots to the right bot mode). Then write each of the 4 binaries to the device. Doing the hold buttons of boot and reset after each binary is written. Then reset at the end.
2022-08-11 13:12:16
2022-01-21 23:38:04
Good luck. DFRobot are at the mercy of whatever MangoPi decide to do, and they're focussed on the MangoPi-MQ Pro. Support is not a strong point for MangoPi, which is sad because I felt the R3 had potential.
Our engineers have solved the problem of the firmware. You can follow the tutorial to try again.
2022-02-18 13:47:32
