Are the +- pins 3.3V or VCC? Most gravity modules are 5V and some are 3.3V?
userHead JaneYu 2022-02-11 17:30:59 28 Views5 Replies
2024-05-29 09:32:30
Is this compatable with the Firebeetle 2 ESP32 C6?
This shield does not support the FireBeetle 2 ESP32-C6 since the C6 changes the pinout.
This product only supports FireBeetle 2 ESP32-E and FireBeetle 2 ESP32-M0.
2024-05-29 11:27:42
2022-10-24 14:54:15
Instead of connecting the motor directly to the shield, you need to connect it to the motor drive module. esp32-e only operates at 3.3V, so it is recommended to use an external power supply for the motor drive.
Shield connected to a relay on digital pin. Supply external 9V to relay to activate the pump (connected to the relay) when signal from ESP32 received? Thanks
2022-10-24 15:10:05
