Hello! Just purchased this and very happy with operation (just FYI, for the code provided in the getMeasureData example once the ENS160 library is installed, I had to change the Se...
JaneYu 2022-04-01 22:32:06 91 Views0 Replies Hello! Just purchased this and very happy with operation (just FYI, for the code provided in the getMeasureData example once the ENS160 library is installed, I had to change the Serial.begin rate from 115200 to 9600 in order to display air quality data on the Arduino IDE serial monitor)
Had a question though - are the I2C pins on this breakout board 5V tolerant? Appreciate the board is powered with 3V3 but if you want to run it from a non 3V3 board do you need a bus logic level shifter ? Thanks
