Also can lithium charger charge 2-cell lithium batteries or only 1-cell?
JaneYu 2022-04-03 15:31:44 28 Views5 Replies Also can lithium charger charge 2-cell lithium batteries or only 1-cell?
2024-06-19 22:19:02
JaneYu
Is the external crystal(32kHz) Clock set as default in the Arduino DF Robot build? This is an awful pain to change using ESp-IDF!!!
JaneYu 2024-06-08 16:37:32
JaneYu
What is this SD card library in the C3 tutorials? Built in? The standard Sd.h? A specific library? You don't give any information!
JaneYu 2022-10-24 15:44:01
JaneYu
Hi, The thickness is 3.5mm without the USB interface, and the maximum thickness is 4.6mm with the USB interface
JaneYu 2022-06-27 23:28:09
JaneYu
Does this board work with PlatformIO in VSCode? I'm having trouble getting the Serial output to print to any monitor. Works with the Arduino 2.0 IDE.
JaneYu
