How long the warranty come with Lattepanda 3 Delta?
JaneYu Products officially sold by DFRobot will be provided with a 3-month warranty.
If you are installing this SBC in a small, unventilated space and running it at full capacity for an extended period of time.
We recommend that you use this aluminum alloy heat sink ** and install a 4040 fan to enhance heat dissipation.
JaneYu Hi, I would love to use this sbc for my gaming project, but the single channel 8gb ram is a bit too small. Is there a possibility for a new delta sbc, that would have 16 gb dual channel ram? I would also love to see an option for no pre-installed ssd, because 64gb is just too small for me. I would buy the Sigma model, but it's just too expensive for my project. Thanks!
JaneYu Sorry, we have no plans to launch LattePanda 3 Delta with 16GB RAM for now.
And our LattePanda 3 Delta does not come with SSD storage. We use eMMC storage in our LattePanda 3 Delta.
You can install your own SSD if you need it.
What is the maximum allowable current load from each of the 5V pins and from each of the 3.3V pins?
Also, what about the maximum current load from the VCC pin?
JaneYu This model of CPU Intel® Celeron® N5105 is support for AVX(Intel Advanced Vector Extensions)?
JaneYu We apologize for the unpleasant experience and will forward this issue to the LattePanda R&D team.
BTW, could you tell us if you are using the original antenna that we shipped with your device?
JaneYu I would just add that a lot of us would pay a pretty good premium for this feature -- even with it taking the price considerably over the $300 mark. and of course having it soldered on is fine -- although you might be able to make the base unit a little cheaper than this existing model by having two empty SO-DIMM slots, I don't know.
JaneYu Hi, you could check the brand new LattePanda sigma.
It got 2 way RAM 16GB.
We released the Sigma just yesterday.
I want to buy this board but I've been trying to find the solution for no sound on the 3/32 version 1 and everything I've found shows DFRobot claiming that they solved the customer's problem while the problem still exists. I installed the drivers that are shown by the DFRobot representative and I still have the same lack of sound.
JaneYu Please contact our technical support with details about your question: [email protected]
Is the new latte panda going to stop working ( brick ) after a couple months like the first latte panda? I'm still very mad about that. There was no reasonable solution at all to fix them. Tech support was a joke.
JaneYu If there is a product problem, please contact us for inspection or repair, please send email to [email protected]
single channel ram? *sadness* dual channel is ultra important for these small machines when using the iGPU
JaneYu Very cool that you released a new Lattepanda. I'm just wondering why you only took USB 2.0 for the USB-C port. the Alpha was already 3.0 back then, which made it good for all in one hubs. Another question arises. Can this Delta keep up with the old Alpha let alone better? especially when it comes to gaming?
or will the alpha also get a new version with these upgrades?
JaneYu
