"When the angle of a servo is changed by external forces during normal operation, the servo can automatically reset and continue working through clutch function, which prevents it ...
JaneYu 2022-08-31 11:15:58 96 Views0 Replies "When the angle of a servo is changed by external forces during normal operation, the servo can automatically reset and continue working through clutch function, which prevents it from being damaged."
I am trying to control a potentiometer with this, while keeping manual controls available by turning it manually. Does this mean it will reset if turned by hand, to its original position? Can this be coded out?
9g 300° Clutch Servo SER0053
