Hi,Many of our robot teams want to replace the expensive Ultrasonic sensors with this URM09. How do you read the distance if distance is larger than 256cm? Because we used a differ...
userHead JaneYu 2022-09-24 11:39:26 102 Views0 Replies
Many of our robot teams want to replace the expensive Ultrasonic sensors with this URM09. How do you read the distance if distance is larger than 256cm? Because we used a different SW SDK, how do you calculate distance from both registers 0x03 and 0x04 for distance > 256cm based on the datasheet posted on Wiki?
0×03Distance Value High-order bitsR0x00-0xFF0x00LSB represents 1CM. e.g. 0x64 represents 100CM
0×04Distance Value Low-order bitsR0x00-0xFF0x00LSB represents 1CM. e.g. 0x64 represents 100CM
Thanks,
John
