How to program the version 2 Maqueen robot? Please share the documentation for this version as there seems to be some command blocks are not found in the V2 extension.
JaneYu 2022-09-26 13:46:04 162 Views6 Replies How to program the version 2 Maqueen robot? Please share the documentation for this version as there seems to be some command blocks are not found in the V2 extension.
On the Maqueen Plus V2: When the LED right or LED left is turned ON, it can no longer be turned OFF in the software. The LED lights will remain on until the robot power is turned off. This is a flaw in the design. Is there another way to turn them off using the Digital/Analog pins?
JaneYu Hi, You can set the corresponding LED pin to low level in the code.
Hello
how to program line sensors in python?? I can't do it (on the old version it was PIN 13 and 14)
JaneYu Hi,
I've got two question about the V2 version :
- Is there an extension for this new version downloadable using MakeCode ?
- Do you certificate that the SR04 work well with the 18650 Lithium battery ?
Thanks for your answer asap cause I have many robots to order.
JaneYu The provided link doesn't contain all the information how to program V2 - for example there is no info how to program servo. There is no command block to control servo at all.
JaneYu
