What are the pinouts for this servo? Which is +, -, and signal? How about adding a wiring diagram to the specifications?
JaneYu 2022-10-21 00:58:23 86 Views3 Replies What are the pinouts for this servo? Which is +, -, and signal? How about adding a wiring diagram to the specifications?
2023-11-06 16:44:26
JaneYu
Hello!
regarding the 2Kg 300° Clutch Servo -
How many teeth does its output gear contain? 24 or 25?
JaneYu 2023-04-22 18:53:00
JaneYu
If I turn the servo with my hand while it is powered on will it still not change his angle values?
I need to set 6 angles that the servo will always go back to the excact position no matter what.
JaneYu
2Kg 300° Clutch Servo SER0056
