Hello, can I leave this sensor on, reading for months continuously, using it as a motion detector ? Or will performance degrade too much after time. Tkx for your answer
JaneYu 2022-11-05 22:06:09 28 Views2 Replies Hello, can I leave this sensor on, reading for months continuously, using it as a motion detector ? Or will performance degrade too much after time. Tkx for your answer
2023-12-04 10:42:49
JaneYu
I2C multiplexer could be set into 8 address. And each address have eight channel.
So we think you can buy 7 Multiplexers to hook up to 50 VL6180Xs.
JaneYu 2022-12-29 13:11:19
JaneYu
i need to use two VL6180X, how should do it? can you provide an example code.
JaneYu
