Can I connect two of them in parallel to get more power?
userHead JaneYu 2022-12-10 03:06:18 100 Views5 Replies
2024-07-27 17:08:06
Sorry didn't found the documentation about this module.
Does it work as an uninterruptible power supply, i.e. it was running in "Charge and discharge" mode, the battery is charged, and the the source goes lost.
Does it go automatically to "Discharge only" and are there a delay between modes?
thank you
2023-10-21 22:16:07
Does it switch seamlessly between voltage in and the battery? I.e it won't temporarily turn off if I connect a charger?
We are sorry that the charger will temporarily off when you switch between the USB and battery.
2023-10-23 10:01:52
We think you could use the CAN-TTL module on the LattePanda
2023-10-23 10:04:30
2023-06-30 16:40:08
Sorry we could not clearly understand your question, this module does not have the USB output interface.
