I have a fermion serial data logger and need to use this with pico pi and python. Does anyone have starters on wiring and code before I senf myself down the wrong path. There doe...
JaneYu 2023-01-11 16:42:27 111 Views2 Replies I have a fermion serial data logger and need to use this with pico pi and python. Does anyone have starters on wiring and code before I senf myself down the wrong path. There doesn't seem to be much documentation alternative to arduino. I am doing this to get data into Matlab.
Many Thanks
I have a fermion serial data logger, but when I initialize it the .txt file is not generated, what can I do?
JaneYu 1. You need to power 3.3-5V on VCC and GND next to RX for more than two seconds, and you can't power on 5V and GND
2. Whether your SD card is formatted as FAT32
3. Do you write data to the RX pin without initialization?
If you above advice could not resolve your problem.
Please send us the testing video via email:
[email protected]
You could upload the video onto the Google Drive and set access to all.
