Hello, I have a question about DFR0936. I believe that the schematic(https://dfimg.dfrobot.com/n... listed above is not correct. If you use such a LCD module, RGB text color functi...
JaneYu 2023-02-01 15:32:49 116 Views0 Replies Hello, I have a question about DFR0936. I believe that the schematic(https://dfimg.dfrobot.com/n... listed above is not correct. If you use such a LCD module, RGB text color function is a real magic!
Please check the schematic PDF and list the correct one.
