Hi, can this detect ppb level concentrations? looking for atmospheric composition measurements.
JaneYu 2023-04-20 06:21:08 108 Views3 Replies Hi, can this detect ppb level concentrations? looking for atmospheric composition measurements.
2023-06-30 12:04:47
JaneYu
The working condition of the probe is -20~50℃,RH15%~90%。
And the PCB is not waterproof.
This means you could exposed it under the sum, but the whole sensor is not waterproof, so the rain may damage the sensor.
JaneYu 2023-06-23 15:33:23
JaneYu
I have an H2S and SO2 probe. Is it normal to have a 0 value of concentration level(ppm) if there is no gas subjected to the probe? And if I test the H2S probe to a SO2 gas, will the concentration value change or will it also be zero?
JaneYu 2023-04-25 12:01:01
JaneYu
The H2 sensor's resolution is 1PPM=0.1PPB, so it could not detect the ppb level concentrations.
JaneYu
