hellow , i need to know about ,can I connect this antenna for this module?https://uploads.disquscdn.c... e?
userHead JaneYu 2024-05-07 19:29:11 35 Views5 Replies
2024-06-04 16:21:57
I recieved this board today. However, when I was programming I could not get the output to my serial monitor using Serial.println("Hello World"). What is the reason for this? How can I display something on the serial monitor?
Would you check if you have set the USB CDC as enabled?
2024-06-04 16:34:17
2024-06-01 11:41:16
Hellow can you send me the step file(or cad) file for this board?
Can you check if the dimension size drawing at the bottom of the wiki has the information you need.
2024-06-03 13:47:50
2024-05-21 19:51:23
Can i connect this battery plug https://uploads.disquscdn.c... your device battery interface?
2024-05-08 14:27:28
This look looks like it could be connected to our ESP32
2023-05-16 14:53:33
There is a 2.4GHz WIFI&BLE Antenna on the board.
