At what nominal speed at 5V ?
userHead JaneYu 2023-05-24 16:34:44 31 Views6 Replies
2024-06-07 14:06:20
If you need a suction pump that runs for a long time, we recommend that you use this type of water pump.
2024-02-29 16:00:51
We're sorry, we don't have that information.
If you want to integrate this Pump in a food-grade item, we don't recommend it. This is because this Pump is not food grade internally.
2023-12-13 04:26:02
hi. Nice Product! i just wanted u guys to know. in case u need more pressure (vacum) u can stack those in series. i tryed it with 4 pumps and achieved a pressure of about 3.3 -3.4 bar / 0.33 - 0.35 Mpa. @5v.
Thank you for the information and your support of DFRobot. We appreciate it very much.
2023-12-13 10:02:29
2023-11-16 00:44:00
Do I need a flyback diode or freewheeling diode when I use it with an Arduino?
We recommend that you use a relay to control this pump
2023-12-07 16:36:40
