Have you considered offering the Signal Adapter PCB as a stand alone product? It could be very useful for reading other sensors that rely on counting switch closures / pulses - ...
userHead JaneYu 2023-06-25 01:01:33 45 Views7 Replies
Have you considered offering the Signal Adapter PCB as a stand alone product? It could be very useful for reading other sensors that rely on counting switch closures / pulses - example: flowmeters, cup anemometers, etc.
2024-08-11 10:51:26
Does anyone know how to zero the rainfall - or rather the bucket tip counter - apart from power cycling? There's a bunch of registers which are mostly read from (in the library code) and only one is written that sets the mm/tip value. I've tried writing to some of the other registers but there didn't appears to be any effect.
It's be nice to zero the rain gauge remotely.
Thanks!
2024-08-08 08:23:23
Hello, I am a new to all this and, I just strated a garden irrigation project. I bought this rain sensor to connect with my ESP32. When I program, I thought to use an interrupt to wake the rain_measure function instead of listning for a signal. In the dry season, we need to continiously listning and waiting for a signal from the rain gauge. I thought to connect the SCL or SCD pin signal to the Pin 34 (any pin), and if an interrupt detected run the rain_measure function. Can I know your experience, ideas and suggestion on this before strat?
Thanks!!
2024-07-01 01:57:16
What can be the maximum length between sensor and electronic board?
2024-05-27 09:16:16
If you are using the ESP32, we recommend that you use I2C mode (set the adapter board on-board toggle to I2C) and follow the instructions below for wiring:
Red->3.3V, Black->GND, Blue->SCL, Green->SDA. https://uploads.disquscdn.c...
2024-01-06 12:31:51
Is there a way to use this rain gauge with M5StickC Plus using UIFlow?
2023-08-16 19:17:10
I would very much be able to buy the rainfall sensor PCB stand alone. I blindly bought the rain bucket itself some time ago without knowing how I was going to connect it :) - Any chance that will be available any time soon?
Sorry, the Rain Bucket and PCB of this product cannot be sold separately.
2023-08-30 18:02:59
