How are these I2C lines protected from ESD, EMI, etc?
userHead JaneYu 2023-07-24 20:27:00 114 Views3 Replies
2024-07-07 22:37:30
Your code still has an error even though you say you have fixed it!!
Wire.write(®, 1); this should be Wire.write(0x10);
Please can you correct...
2024-01-13 23:16:36
It would be cool to have code for turning module off for deepsleep.
Just use this library, the sensor is powered down after check:
https://github.com/Starmbi/...
2024-01-13 23:30:34
