Is it possible to limit the sensor to 30mm? The sensor is installed in a tube that has a diameter of 40mm and it always detects the inside of the tube and not the object that passe...
userHead JaneYu 2024-04-19 01:19:41 116 Views0 Replies
Is it possible to limit the sensor to 30mm? The sensor is installed in a tube that has a diameter of 40mm and it always detects the inside of the tube and not the object that passes through.
