Which of the ICs on the Raspberry Pi 5 need the 4 thermal silicone pads that come with this heatsink?update: if you look at the bottom of the heatsink, you can see where the pads s...
JaneYu 2024-04-29 02:36:30 99 Views0 Replies Which of the ICs on the Raspberry Pi 5 need the 4 thermal silicone pads that come with this heatsink?
update: if you look at the bottom of the heatsink, you can see where the pads should be placed.
