What expansion boards does UNIHIKER K10 support?
userHead JaneYu 2025-03-14 17:13:46 890 Views1 Replies
2026-07-24 16:34:57
UNIHIKER K10 has the same edge connector layout as the micro:bit, so it is compatible with most micro:bit expansion boards. You can refer to this list to see the supported expansion boards: Expansion board Compatible list.
