TroubleshootingArduino
Need help combining Arduino + IO expansion shield v7 + Digi XBee 3
userHead Luke00 2025-04-25 22:26:37 1476 Views0 Replies
I am trying to transmit some messages between two Arduinos using the Digi XBee 3 module and IO expansion shields. I am having some issues as there is no print out in the serial monitor on the receiving side. I suspect I have misinterpreted the pinout of the expansion shield and as such the pins in the Arduino code is wrong. The modules themselves have been confirmed to be in a network together using XCTE.
This is the code of the transmitter:
#include <SoftwareSerial.h>
// XBee connected to pins 0 (RX) and 1 (TX)
SoftwareSerial xbee(0, 1);
  xbee.begin(9600);
  Serial.begin(9600);  // For debugging
  randomSeed(analogRead(0));
  String message = "Msg-" + String(random(1000, 9999));
  xbee.println(message); // Send to XBee
  Serial.println("Sent: " + message); // Debug
  delay(3000); // Wait 3 seconds before sending next message
This is the code of the receiver:
  Serial.begin(9600);    // For monitoring on the laptop
  xbee.begin(9600);      // Communication with the XBee
  Serial.println("Receiver ready...");
void loop() {a
  if (xbee.available()) {
    String received = "";
    while (xbee.available()) {
      char c = xbee.read();
      received += c;
    Serial.print("Received: ");
    Serial.println(received);
Any help would be appreciated. As mentioned, I suspect the issue lies with the expansion shield and the pins.
