SKU: SEN0623 (C1001) FCC approval
rfsl 2025-04-30 14:17:42 1394 Views4 Replies SKU: SEN0623 (C1001) for 61~61.5GHz:
1. What is the signal bandwidth?
2. How do you set frequency = 61.125 GHz? (Do I use Arduino IDE code?)3. Can you provide me the antenna gain report document for mmWave 60 GHZ antenna? FCC is asking for this for my device
2025-05-02 12:00:47
rfsl
Hello can you send me the Antenna Gain Report? It's very urgent for FCC approval. Thank you!
rfsl JaneYu
wrote:
2025-05-06 10:21:55 1 Replies
2025-04-30 15:51:41 ![]()
sun.haihui
Sleep mode: starting at 61GHz, bandwidth 1.28GB
Fall mode: starting at 61GHz, bandwidth of 3G
Currently unable to modify frequency
The following image is a screenshot of the gain report:
sun.haihui 2025-04-30 14:44:12
rfsl
For “Antenna Gain Report” here's an example: https://fccid.io/K44523700/RF-Exposure-Info/Antenna-Gain-Report-7157549.pdf
rfsl
