Gravity: 0-10V 15-Bit ADC Module - i2c connection issue with ras pi 4
userHead Pol.Nau 2025-05-07 21:13:49 1451 Views1 Replies
https://www.dfrobot.com/product-2917.html
After having bought the DFRobot Gravity for the purpose of connecting it  between my raspberry pi 4 and my graf silentio pump which has a 0-10v connector to read the water level inside the water tank, I wanted to make an api which gives the value (percentage) from how full the tank is, so that I could add it in other home automations. This seems to not work out, as i somehow have problems when i try to read the data from the 0-10v connection.
when trying "i2cdetect -y 1" on the raspberry pi it will show me the right connection (0x48) and i then try to read data from it, but it will not show any data
do i have to make a1 or a0 to 1 and what do those switches there do exactly? do they enable the inputs or what do they exactly do?
Would appreciate help!:)
2025-05-07 22:10:22
I somehow have doubts if this module is actually there for reading but rather for writing analog output, it just seems so weird that it doesn't get any values even if I try to take a battery and connect gnd and an2 it doesn't give any values?
userHeadPic Pol.Nau
