HUSKYLENS screen broken, unable to find serial port
userHead Jerry.C. 2025-05-10 03:00:17 2128 Views2 Replies
My HUSKYLENS's screen looks like this:
(the bottom left corner is fine, the rest is broken with weird stripes)
I also can't find it's serial port.
Does anyone else have a similar issue or know how to fix this?
2025-07-23 19:20:16
If your HuskyLens screen is broken and no serial port appears when connected, the device may not be powering correctly or the internal hardware could be damaged. Try using a known working data USB cable and check for recognition on another system. Firmware recovery might still be possible if detected. https://**.co/
userHeadPic Jack.James
2025-05-10 03:18:16
Note: I mean I can't find the serial port on device manager in windows, for uploading the firmware. I think I can still connect it to an Arduino / microcontroller.
userHeadPic Jerry.C.
