DFRobot SIM7000A unresponsive on the filed
userHead George.D 2025-05-11 10:27:12 1211 Views0 Replies
My SIM7000A attached to Arduino UNO WiFi Rev2 becomes unresponsive on the filed. The only way to reset the SIM7000A module is by pressing the BOOT button, but this unpractical given the the vehicle driver won't have access to this button. Create a Function in my code try different rests: Logical, hardware and power, but it is not working. Can someone shed light as to how to set up a reset Function that works.
This the code I have at the moment (not working):
bool resetSIM7000A() {
  Serial.println(F("Attempting module reset based on DFRobot documentation..."));
  // First try logical reset
  Serial.println(F("Trying logical reset..."));
  sendATCommand("AT+CFUN=1,1", 1000);
  delay(12000);  // Wait for module to restart
  String response = sendATCommandWithResponse("AT", 3000);
  if (response.indexOf("OK") != -1) {
    Serial.println(F("Logical reset successful"));
    sendATCommand("ATE0", 1000);
    sendATCommand("AT+CGNSPWR=1", 2000);
    return true;
  // Try hardware reset according to DFRobot specs
  Serial.println(F("Trying hardware reset per DFRobot specs..."));
  pinMode(PIN_RESET, OUTPUT);
  digitalWrite(PIN_RESET, HIGH);  // Ensure it starts HIGH (normal state)
  delay(100);
  digitalWrite(PIN_RESET, LOW);   // Pull LOW to trigger reset
  delay(100);                     // Brief pulse
  digitalWrite(PIN_RESET, HIGH);  // Return to HIGH (normal state)
  delay(15000);                   // Wait for module to restart
    Serial.println(F("Hardware reset successful"));
    return true;
  // Try power key sequence according to DFRobot specs
  Serial.println(F("Trying power key sequence per DFRobot specs..."));
  pinMode(PIN_PWRKEY, OUTPUT);
  digitalWrite(PIN_PWRKEY, HIGH);  // Ensure it starts HIGH (normal state)
  delay(100);
  digitalWrite(PIN_PWRKEY, LOW);   // Pull LOW to trigger power on/off
  delay(1500);                     // Hold for 1.5 seconds
  digitalWrite(PIN_PWRKEY, HIGH);  // Return to HIGH (normal state)
  delay(20000);                    // Wait for module to power cycle
    Serial.println(F("Power key sequence successful"));
    return true;
  Serial.println(F("All reset methods failed"));
  return false;
Thanks!
