constant - 12V DC Motor 350RPM w/Encoder (12kg*cm)
Tistar.Rak 2025-05-24 04:09:05 913 Views0 Replies Hi together,
unfortunately I could not find the values for the following properties of the 12V DC Motor 350RPM w/Encoder (12kg*cm) anywhere.
Does someone have the values for:
- k_t: torque constant [Nm/A]- k_v: voltage constant [V/omega]- k_: proportionality constant [unitless])- motor efficiency @max. efficiency rpm
Best regards and many thanks if someone them
Tistar
