Troubleshooting
SEN0344 Schematic Symbol Import Issue on KiCad
userHead muinmist 2025-05-27 21:30:22 1025 Views1 Replies
The schematic symbol of the SKU of SEN0344 containing Heart Rate and Oximeter Sensor V2 cannot be properly imported into KiCad. It appears as below:
Here's my KiCad version info:
Version: 9.0.2, release build
Libraries:
   wxWidgets 3.2.6
   FreeType 2.13.3
   HarfBuzz 10.2.0
   FontConfig 2.15.0
   libcurl/8.11.1-DEV Schannel zlib/1.3.1
Platform: Windows 10 (build 19045), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: Intel, Intel(R) HD Graphics 620, 4.6.0 - Build 31.0.101.2111
Build Info:
   Date: May 7 2025 02:29:49
   wxWidgets: 3.2.6 (wchar_t,wx containers)
   Boost: 1.86.0
   OCC: 7.8.1
   Curl: 8.11.1-DEV
   ngspice: 44
   Compiler: Visual C++ 1942 without C++ ABI
   KICAD_IPC_API=ON
I downloaded the symbol files from DFRobot Wiki page and other symbols downloaded from SnapEDA works fine. Can someone please give me any solution how I can properly import it so that I don't need to edit it in Symbol Editor? Thanks.
2025-06-03 06:52:14
The issue was resolved by editing the symbol text file on Notepad. It is also possible by editing the properties of each pin inside Symbol Editor.
userHeadPic muinmist
