General ArduinoGravity
SEN0189 - Low Power mode
userHead Lars Willas.Dreyer 2025-06-10 20:01:04 778 Views0 Replies
I am working on a SEN0189, which is read using the analogRead()-function. Since the SEN0189 takes quite a lot of power, I was hoping for some clarification regarding:
Does the sensor only read/pull power after the analogRead-function is called? If so, how much power does it pull when not measuring?
If the sensor does read “continously”, is there a way to put it in sleep mode in between measurements to reduce power consumption?
