DFR0669 + DFR0654: trouble with "createbutton" function
userHead Staldy 2025-06-29 23:16:57 1141 Views2 Replies
Hello everyone,
I’m a beginner in C programming and I’m using a 3.5″ DFR0669 screen with a FireBeetle ESP32, coding on the Arduino platform.
My project is to build an alarm clock by adding a DFPlayer Pro module, a speaker, and a large physical button for stop/snooze. Eventually, it will support up to four alarms with recurrence and allow me to choose a custom song for each.
The first screen connects the FireBeetle ESP32 to the network and lets you select the language, using credentials stored in a text file on an SD card attached to the display. After that, I plan to turn off Wi-Fi and synchronize with an NTP server once a day.
I’ve created my first screen and I’m now trying to add buttons to switch to the “Help” screen and to the next screen (Clock/Settings). I’m struggling with the createButton() function: I tested the example and it works fine, but I can’t implement it in my own code.
Actually, the font changes and a blue/gray area appears on the left as soon as I add the button, and my icon disappears, it doesn’t look right. Can someone help me fix this? Thanks!
I'm sharing the working/not working codes with pictures :-)
Working code and the result:
#include "WiFi.h"
#include "SD.h"
#include "SPI.h"
#include "DFRobot_UI.h"
#include "DFRobot_GDL.h"
#include "DFRobot_Touch.h"
#include "time.h"
#include "icon.h"
#define TFT_DC   D2
#define TFT_CS   D6
#define TFT_RST  D3
#define TFT_SD   D7
#define TFT_BL   D13
DFRobot_ILI9488_320x480_HW_SPI screen(TFT_DC, TFT_CS, TFT_RST, TFT_BL);
DFRobot_Touch_GT911 touch;
DFRobot_UI ui(&screen, &touch);
// Placeholder color (light gray)
#define CLR_PLACEHOLDER COLOR_RGB565_LGRAY
// Wi-Fi and language configuration
char ssid[64]     = "";
char password[64] = "";
char lang[4]      = "en";
// Day names in French and English
const char* dayNames_fr[] = {
  "DIMANCHE","LUNDI","MARDI","MERCREDI","JEUDI","VENDREDI","SAMEDI"
const char* dayNames_en[] = {
  "SUNDAY","MONDAY","TUESDAY","WEDNESDAY","THURSDAY","FRIDAY","SATURDAY"
// Layout constants
const int padH        = 15;
const int padV        = 13;
const int iconSize    = 48;
const int iconSpacing = 6;
const int box1Size    = 60;
const int box2Size    = 138;
const int boxSpacing  = 18;
const int radius      = 12;
// Draw a small icon with a rounded border
void drawIconBox(int x, int y, const unsigned char* icon, uint16_t color) {
  screen.drawRoundRect(x, y, box1Size, box1Size, radius, color);
  screen.drawBitmap(x + iconSpacing, y + iconSpacing,
                    icon, iconSize, iconSize, color);
// Draw a larger “language” box with label
void drawLangBox(int x, int y, const unsigned char* icon,
                 const char* label, uint16_t color) {
  screen.drawRoundRect(x, y, box2Size, box1Size, radius, color);
  screen.setTextColor(color);
  screen.setTextSize(3);
  screen.setCursor(x + box1Size + iconSpacing, y + 18);
  screen.print(label);
  Serial.begin(115200);
  delay(500);
  ui.begin();
  // 1) Initialize display
  screen.setRotation(1);
  screen.fillScreen(COLOR_RGB565_BLACK);
  // 2) Initialize SPI for SD card and then Wi-Fi and NTP
  SPI.begin(18, 19, 23, TFT_SD);
  // Placeholder: draw all status icons in gray
  int x0 = padH;
  int y0 = padV + box1Size + boxSpacing;
  drawIconBox(x0 + 0*(box1Size+boxSpacing), y0, icon_sd_nok, CLR_PLACEHOLDER);
  drawIconBox(x0 + 1*(box1Size+boxSpacing), y0, icon_file_nok, CLR_PLACEHOLDER);
  drawLangBox(x0 + 2*(box1Size+boxSpacing), y0, icon_lang, "  ", CLR_PLACEHOLDER);
  drawIconBox(x0 + 4*(box1Size+boxSpacing), y0, icon_wifi_off, CLR_PLACEHOLDER);
  // 3) Check SD card
    delay(500);
  bool sdOk = SD.begin(TFT_SD);
  uint16_t sdColor = sdOk ? COLOR_RGB565_GREEN : COLOR_RGB565_RED;
  // Clear area before redrawing
  screen.fillRect(x0 + 0*(box1Size+boxSpacing),
                  y0,
                  box1Size,
                  box1Size,
              sdOk ? icon_sd_ok : icon_sd_nok,
              sdColor);
  // 4) Check setup.txt on SD
  bool fileOk = false;
  if (sdOk) {
    File f = SD.open("/setup.txt");
    if (f) {
      fileOk = true;
      while (f.available()) {
        String L = f.readStringUntil('\n');
        L.trim();
        if (L.startsWith("SSID="))  strncpy(ssid,     L.c_str()+5, sizeof(ssid)-1);
        if (L.startsWith("PASS="))  strncpy(password, L.c_str()+5, sizeof(password)-1);
        if (L.startsWith("LANG="))  strncpy(lang,     L.c_str()+5, sizeof(lang)-1);
      f.close();
  uint16_t fileColor = fileOk ? COLOR_RGB565_GREEN : COLOR_RGB565_RED;
  screen.fillRect(x0 + 1*(box1Size+boxSpacing),
                  y0,
                  box1Size,
                  box1Size,
              fileOk ? icon_file_ok : icon_file_nok,
              fileColor);
  // 5) Display language status
   delay(500);
  bool validLang = (strcmp(lang,"fr")==0)||(strcmp(lang,"en")==0);
  char langLabel[3] = {0};
  if (validLang) strcpy(langLabel, strcmp(lang,"fr")==0?"FR":"EN");
  else           strncpy(langLabel, lang, 2);
  uint16_t langColor;
  if (!fileOk)        langColor = COLOR_RGB565_ORANGE; // default if no file
  else if (validLang) langColor = COLOR_RGB565_GREEN;
  else                 langColor = COLOR_RGB565_RED;
  screen.fillRect(x0 + 2*(box1Size+boxSpacing),
                  y0,
                  box2Size,
                  box1Size,
              icon_lang, langLabel, langColor);
  // 6) Wi-Fi connection attempt
   delay(500);
  WiFi.begin(ssid, password);
  unsigned long t0 = millis();
  while (WiFi.status()!=WL_CONNECTED && millis()-t0<10000) {
    delay(200);
  bool wifiOk = (WiFi.status()==WL_CONNECTED);
  uint16_t wifiColor = wifiOk ? COLOR_RGB565_GREEN : COLOR_RGB565_RED;
  screen.fillRect(x0 + 4*(box1Size+boxSpacing),
                  y0,
                  box1Size,
                  box1Size,
              wifiOk ? icon_wifi_on : icon_wifi_off,
              wifiColor);
  // 7) Configure NTP so getLocalTime() will work
  configTzTime("CET-1CEST,M3.5.0/2,M10.5.0/3", "pool.ntp.org");
  // 8) Draw Help / Refresh / Check icons (temporary buttons)
  drawIconBox(405,                padH, icon_help,    COLOR_RGB565_BLUE);
  drawIconBox(405 - (18 + 60),    247,  icon_refresh, COLOR_RGB565_ORANGE);
  drawIconBox(405,                247,  icon_check,   COLOR_RGB565_DGREEN);
  ui.refresh();  // handle UI touch callbacks (if any)
  // Update date/time once per minute
  static char lastDate[32] = "";
  static char lastTime[6]  = "";
  static unsigned long lastCheck = 0;
  if (millis() - lastCheck < 1000) return;
  lastCheck = millis();
  struct tm ti;
  if (!getLocalTime(&ti)) return;
  // Format date string and time string
  char d[32], t[6];
  const char** dn = (strcmp(lang,"fr")==0) ? dayNames_fr : dayNames_en;
  snprintf(d, sizeof(d),
           "%s %02d.%02d.%04d",
           dn[ti.tm_wday],
           ti.tm_mday,
           ti.tm_mon + 1,
           ti.tm_year + 1900);
  snprintf(t, sizeof(t),
           "%02d:%02d",
           ti.tm_hour,
           ti.tm_min);
  // Redraw if changed
  if (strcmp(d, lastDate) || strcmp(t, lastTime)) {
    strcpy(lastDate, d);
    strcpy(lastTime, t);
    screen.fillRect(15, 180, 300, 70, COLOR_RGB565_BLACK);
    screen.setTextColor(COLOR_RGB565_WHITE);
    screen.setCursor(15, 180);
    screen.print(d);
    screen.setCursor(15, 210);
    screen.print(t);
I add the first button:
#include "WiFi.h"
#include "SD.h"
#include "SPI.h"
#include "time.h"
#include "icon.h"
#define TFT_DC   D2
#define TFT_CS   D6
#define TFT_RST  D3
#define TFT_SD   D7
#define TFT_BL   D13
char ssid[64]     = "";
// Layout constants
//Callback function for three buttons
void btnCallback(DFRobot_UI::sButton_t &btn,DFRobot_UI::sTextBox_t &obj) {
 /* String text((char *)btn.text);
   if(text == "ON"){
    obj.setText("you have touch button on");
   else if(text == "OFF"){
    obj.setText("you have touch button off");
   else if(text == "clr"){
    obj.deleteChar();
  delay(500);
  ui.begin();
//ui.setTheme(DFRobot_UI::MODERN);
  int x0 = padH;
  // 3) Check SD card
    delay(500);
                  y0,
                  box1Size,
                  box1Size,
              sdColor);
  if (sdOk) {
    if (f) {
      fileOk = true;
        L.trim();
      f.close();
                  y0,
                  box1Size,
                  box1Size,
              fileColor);
   delay(500);
  uint16_t langColor;
                  y0,
                  box2Size,
                  box1Size,
   delay(500);
    delay(200);
                  y0,
                  box1Size,
                  box1Size,
              wifiColor);
  //Create a button control on the screen
  DFRobot_UI::sButton_t & btn1 = ui.creatButton();
  //Set the name of the button
  btn1.setText("HELP");
  btn1.bgColor = COLOR_RGB565_BLUE;
  btn1.setCallback(btnCallback);
 // btn1.setOutput(&tb);
  ui.draw(&btn1,405,padH,box1Size,box1Size);
  //drawIconBox(405,                padH, icon_help,    COLOR_RGB565_BLUE);
  struct tm ti;
  char d[32], t[6];
           dn[ti.tm_wday],
           ti.tm_mday,
           ti.tm_mon + 1,
           ti.tm_year + 1900);
           "%02d:%02d",
           ti.tm_hour,
           ti.tm_min);
    screen.print(d);
    screen.print(t);
2025-07-03 14:45:27
The UI button drawing might set a font/color internally and not reset it. Always set your desired font and color after you draw buttons:
// After drawing buttons
screen.setFont(&FreeSans9pt7b);  // or whatever font you want
userHeadPic ahsrab.rifat
Staldy wrote:
Thank you !
For now, I’ve placed the touchscreen on the side and I’m using an RGB button and an AD keyboard, and that gets the job done.
2025-07-08 14:06:08
