SEN0366 Lux Sensitive when target in Direct Sunlight
Gerry.Lavender 2025-07-12 06:01:38 737 Views1 Replies I have tested the SEN0336 indoors. Seems to work great to about a tenth of an inch resolution. Outdoors it stops responding when aimed at a target like a patio surface in direct sunlight. I kept the device itself shaded.
Any suggestions. I was needing it for outdoor use with targets in direct sunlight.
2025-07-12 23:29:11 Measuring Range: indoor 0.05-50m, outdoor 0.05-80m. Maybe outside it is getting out of the range.
ahsrab.rifat
ahsrab.rifat
