Ambient Light Sensor technical drawing
userHead Bart.Woodstrup 2025-07-13 07:09:17 871 Views2 Replies
Is there a technical drawing for the Ambient Light Sensor?
https://www.dfrobot.com/product-2183.html
2025-07-13 16:36:06
Here is a dimension diagram. https://wiki.dfrobot.com/SKU_SEN0611_Gravity_Color_Temperature_and_Ambient_Light_Sensor
userHeadPic ahsrab.rifat
Bart.Woodstrup wrote:
Thank you! Though I was hoping for a drawing of the “semisphere” dome. I'll just work off of these dimensions:
Dimension: inner diameter 22mm, outer diameter 26mm, shell diameter 28.5mm, semisphere height 18mm
2025-07-14 03:49:27
