DFR0342, How to set the IP address?
userHead JaneYu 2024-07-24 11:13:46 745 Views1 Replies
2025-07-24 11:14:27
Open your Network connection properties, and check the IPv4 Address and Gateway. The first three numbers should be set as same as on your board. The last number can be any number between 0-255, as long as it is not occupied by any other devices. DFR0342_Gateway.png
