How to use the onboard micro-SD card slot?
userHead JaneYu 2024-07-24 11:16:09 825 Views1 Replies
2025-07-24 11:16:26
Use it as the normal one using Arduino SD library is ok. Note that because the W5100 and SD card share the SPI bus, only one can be active at a time. For more, please check on Arduino, Arduino Ethernet Shield.
