Hello, Can it be used with other transmitters and receivers?
JaneYu 2024-07-11 21:30:20 730 Views0 Replies Can it be used with other transmitters and receivers?
2024-07-11 21:30:20 Yes, but make sure that the encoding format and rate are the same,different devices D0-D3 may not correspond exactly. The encoding format of the transmitter is EV1527, and the transmission rate is less than 10K; the decoding format of the receiver is EV1527, and the decoding rate is 0~10K.
JaneYu
JaneYu
