No output/wrong data? Check code, wiring, power & baud rate.
JaneYu 2024-07-11 19:48:06 644 Views0 Replies No output/wrong data? Check code, wiring, power & baud rate.
2024-07-11 19:48:06 Caused by power fluctuations,first connect the sensor to the controller, and then supply power to the entire system to solve the problem
JaneYu
JaneYu
