Motor won't spin despite power light? Check code, wiring, and driver circuit.
JaneYu 2024-07-11 05:26:47 528 Views0 Replies After installing a battery in the car, the motor still can’t be controlled to rotate by burning program while the power light is on?
2024-07-11 05:26:47 Perhaps the battery is dead, and it is recommended to replace it with a fully charged one. When the battery voltage is lower than 2V, the LED on the board and other functions can work normally, but the motor can’t rotate due to insufficient power.
JaneYu
JaneYu
