Why does the button module sometimes not work after downloading the program?
userHead JaneYu 2024-07-11 14:40:11 531 Views0 Replies
2024-07-11 14:40:11 First, check if the DIP switch address of the button module is set correctly; second, if you have changed the module I2C address during powering on, try powering down and reconnect. userHeadPic JaneYu
