Test with simulated lightning signals or lab equipment to verify sensor functionality
userHead JaneYu 2024-07-11 22:20:58 849 Views0 Replies
How will I verify that the sensor is working properly if there is no thunderstorm in my area for an extended period of time?
2024-07-11 22:20:58 You can test the sensor by placing it around a large number of computers or RF transmitters, or next to a running microwave oven. This way you may get Noise level too high/Distruber discovered! That is, the getInterruptSrc() function may return 2 or 3. You can also adjust the sensitivity of the sensor to other EMI devices by adjusting the setNoiseFloorLvl() function. userHeadPic JaneYu
