Check power, wiring, signal connections, and motor driver configuration first.
userHead JaneYu 2024-07-11 01:30:44 583 Views0 Replies
Comman wiring mistakes might cause unexpected problem, like: The motor is not response to the command or signal, or the motor can not rotate continuously. You can check if you made some mistake in the list below.
2025-07-24 14:46:50 Please check:Bad/ loose connection. That is some bad wire or wrong connection. One possible wrong connection is happened on the connecter, showing as the picture at right.Tx and Rx connected wrong. Generally, the connection should be Tx-Rx, Rx-Tx (Device A - Device B), but some product is designed for special purpose that the lable Tx on PCB is Rx actually, if so, you would better check its schematic to see if it's ture and exchange the Tx, Rx connection.If you connect the wires + and - of power supply in reverse way.
For A2 2.2 For A2 3
